Creating Global Configurations
A global parameter configuration stores the configuration changes to be applied in your global parameter work order. You can add a global parameter configuration from an existing software (schema) version.
- Expand the Configuration Manager slider and click Global parameters.
- In the GP Config tab, click Add.
In the
			 Add global configuration pane, complete the following fields:
Note: The Selected Managed device field is not available when the Software version selection is made.Name Description Configuration name field The unique global parameter configuration name that is an alphanumeric value from 1 to 24 characters with no spaces and no special characters with the exception of the hyphen (-) and underscore (_). Note: When you choose a name for a new global parameter configuration, this name must not start with the prefix "ID".A validation error (invalid oc name) occurs if the above rules are not followed. Description field The description of the global parameter configuration. Global configuration seeded from drop-down list Select Software version to load the existing software schema provided by the product plugin (for example SD plugin). The data schema for a selected device software version model and default values are loaded to the global parameter configuration. If you select this option, you must select a platform and software version. The available platforms and software versions are determined by the configuration schemas supported by the product plugin. Category Select the ellipsis icon (...). In the Select Category dialog box, select SD for the Session Delivery (SD) element manager product category, and click OK. Component drop-down list The available network function (NF) components are driven by the selection of the SD category (default). Platform drop-down list Select the device hardware platform of the targeted devices. Supported software version drop-down list Select the software version of the device you want to use for your global parameter configuration.
Click
			 Apply. The following actions are taken:
The global parameter configuration appears in the GP Config table.
