Apply an RCM to a Device
- Expand the Configuration Manager slider, and select .
- Select the RCM that you want to apply to a device, and click Apply.
- In the Apply RCM to configuration pane that appears, select the ellipse icon (...) next to the Select managed device field.
- In the Select managed device dialog box, navigate the desired folder structure to your device.
- Select the device, and click OK.
- In the Apply RCM to configuration pane, click Next.
- In the Configure RCM input variables pane, configure the input parameters for your device and click Finish when you are done.
