PreviousNextJavaScript must be enabled to correctly display this content
View a Backup Schedule
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC) and the Enterprise Communications Broker (ECB).
On the
Configuration Manager slider, select
Configure archive > Schedules.
In the
Schedules pane, Session Element Manager displays the following columns:
Name
Description
Parent Group
The parent network function (NF) group that is provided by the user or
Oracle Communications Session Element Manager plugin.
Source
The name of the NF target device(s) or device group that needs to be archived.
Frequency
The scheduled backup frequency.
First scheduled
The first time the schedule is started.
Last run time
The last time a scheduled backup was done.
Platform version
The current hardware version. If it is a device group, the value is N/A.
Software version
The current software version. If it is a device group, the value is N/A.
