Using the Home Device Group
You can add your NFs to the default Home device group if no other groups need to be created. Use this group with the following conditions:
- You must be assigned full administrative privileges to view this device group.
- You cannot rename this device group.
- You cannot delete this device group.
- When adding a device, the Home device group displays in the Add device group dialog box only if you have not targeted a previous device group from the table.
