System Configuration Element
Ensure the system-config element, which establishes that general system information and settings for the product device is configured with the following SNMP and networking parameters:
- System contact information.
- System ID.
- Physical location of the system.
- SNMP is enabled on the system.
- Traps are enabled on the system.
- The network default gateway IP address is configured.
For more information about configuring these parameters, see your product device configuration documentation.
For Oracle Enterprise products, check system configuration supports only the Enterprise Session Border Controller (ESBC) and the Enterprise Communications Broker (ECB).
