Overview
The Oracle Communications Session Element Manager has the following sliders:
- Dashboard Manager—The dashboard summary view of at-a-glance status and key performance indicators for your managed devices.
- Device Manager—Use this slider to simplify the management of small to large networks of devices.
- Security Manager—Use this slider to configure any security privileges that are specific to Oracle Communications Session Delivery Manager and the Oracle Communications Session Element Manager product plugin. See the Security Manager chapter in the Oracle® Communications Session Delivery Manager Administration Guide for more information.
- Configuration Manager—Use this slider to do the following:
- You can select from distinct configuration view styles that display a hierarchical view of infrastructure elements and their physical and logical components (for example, physical interface, virtual interface, realm, signaling service, session agents, and so on).
- View the local configuration, change the configuration and push these changes to a device.
- Use the Global Parameter, Offline Configurations, and Reusable Modules folder nodes to make configuring devices easier and manage software for multiple networks.
- Use the features in the Configure archive folder node to perform automated and manual configuration backup for a device and restore configurations to a device from the archive.
- Fault Manager—View events, alarms, and trap summary data. See the Fault Manager chapter in the Oracle® Communications Session Delivery Manager Administration Guide for more information.
- Performance Manager—View SNMP, IP, environmental and other performance statistics collected from product devices.
