Creating Physical Interfaces
Use Oracle Communications Session Element Manager to add a physical interface for your session delivery device.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).
  1. Expand the Configuration Manager slider, and click Devices.
  2. In the Managed Devices pane, select a device, and click Load.
  3. In the navigation panel, click the Global Settings folder to expand the configuration navigation tree for the loaded device.
  4. In the navigation panel, click Interfaces.
  5. In the Interfaces pane, click Add in the Physical interface table.
  6. In the Add Physical interface dialog, complete the following fields:
    Name Description
    Name field Enter a unique name for this interface using any combination of characters entered without spaces.
    Operation type drop-down list Select one of the following physical interface types:
    • Maintenance—The management physical interface that is used for management protocols or high availability (HA).
    • Control—This is a legacy parameter that can also be used to configure the management physical interface.
    • Media—The media interface, which carries production traffic.
    Slot field Enter the slot of this physical interface (0 or 1).
    Port field From left to right as you face the chassis, the possible values are from 0 to 3.
  7. Click Apply.
  8. In the Success dialog, click OK.
    The newly-added physical interface appears in the Physical interface table.
