Add an Element to an Existing Reusable Configuration Module
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).- Expand the Configuration Manager slider and select Configuration Tools > Reusable Modules.
- Select the RCM you want to modify, and click Load.
- Select the element type row from the Elements defined table and click Add.
In the
Add Element dialog box, complete the following fields:
Name Description Type drop-down list (Required) Select the type of element to be defined. Name field (Required) Enter a unique name for the element action. Description field Enter a description for the element action. Element action drop-down list Select the configuration action for the targeted element. You can add an element to a configuration, modify an existing configuration element, or remove a configuration element. - An ADD element may not contain any sub-element with a MODIFY or DELETE action.
- A MODIFY action cannot be performed on the parent of any configuration element that is part of an Order Group.
- Required sub-elements cannot be removed from RCM elements with a top level ADD action.
- A MODIFY or DELETE top-level element can only change into an ADD action if all its required sub-elements exist.
- Select ADD to add an element if it is not found in the target work flow.
- Select MODIFY to modify the element if it is found in the target work flow.
- Select DELETE to delete the selected element if it is found in the target work flow.
The provisioning policy rules apply to each RCM action for each element instance level. - Click Add Variable.
- In the the Add element dialog box, complete any element-specific parameters. See your product device documentation for more information about these parameters.
- Click Apply.
- Click OK to dismiss the confirmation dialog.
