PreviousNextJavaScript must be enabled to correctly display this content
Creating Network Interfaces
You must create a default network interface that is associated with your physical interface.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).
Expand the
Configuration Manager slider, and click
Devices.
In the
Managed Devices pane, select a device, and click
Load.
In the navigation panel, click the
Global Settings folder to expand the configuration navigation tree for the loaded device.
Interfaces.
In the
Interfaces pane, click
Add in the
Network interface table.
Click the arrow on the
Guidelines box to view dependencies regarding your network interface.
In the
Add Network interface dialog, complete the following fields:
Name
Description
VLAN number field
If this network interface is not channelized, keep this port set to 0 (default). If this network interface is channelized, enter the appropriate VLAN number (sub-port ID).
Physical interface drop-down list
Click the physical interface to which this network interface corresponds in the drop-down list.
Click
Apply.
In the
Success dialog, click
OK.
The newly-added network interface appears in the
