TCP Tab
| Name | Description |
| Local address | The local IP address for this TCP connection. In the case of a connection in the listen state, the value is 0.0.0.0 |
| Local port | The local port number for this TCP connection. |
| Remote address | The remote IP address for this TCP connection. |
| Remote port | The remote port number for this TCP connection. |
| State | The state of this TCP connection. Valid values are:
