PreviousNextJavaScript must be enabled to correctly display this content
Saving Net-Net SBC Configurations
During the save and activation process, other users cannot make changes to the device.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).
Expand the
Configuration Manager slider, and click
Devices.
In the
Managed Devices pane, select a device, and click
Load.
In the
Managed Devices panel, click the
Home folder to expand the configuration navigation tree for the loaded device.
Select the device, and click
Update.
In the
Update configuration dialog, click one of the following update operations:
Save & activate configuration—(Default) Invokes the save and activate process
Save configuration—Invokes the save process.
Activate configuration—Makes this configuration the running configuration on the device.
Click
OK.
In the
Information dialog, click
OK.
The operation you selected appears in the
Device tasks table.
In the
Device tasks table you can the operation row and click
View log to get logging data for your device or save logging data to file on your local system.
