View Work Order and Device Group Task Logs
Use one of the following actions to access work order or device task information:
- Global parameter work order—Configuration Manager > Global Parameters and click the Admin tab.
- Software upgrade work order—Device Manager > Software upgrade > Work order administration
- All work order types—Dashboard Manager > Work order view > Work order administration
In the
Work orders table for a global parameter work order that is running or executed, click
Logs to view the following logging information:
- Pause, start or resume, abort or rollback, and commit actions.
- Pause, resume, abort or rollback, and resubmit task actions.
In the
Work orders table for a software upgrade work order that is running or executed, click
- Software archive and software upgrade actions.
In the
Device group tasks table for device tasks that are associated with a global parameter work order or software upgrade work order that is running or executed, click
- Global parameter configuration changes, including addition, modification, and deletion of parameters.
