Information for Oracle Enterprise Communications Broker Users
The Oracle Communications Session Element Manager (SEM) supports using the Oracle Enterprise Communications Broker (ECB) with the full functionality of the SEM Dashboard, Device, Performance, and Fault managers. In the SEM Configuration Manager, SEM supports only the auto-backup functionality for the ECB.
From the SEM GUI, you can launch the ECB login page and perform operations on the ECB.
The SEM does not support:
- Loading the ECB configuration with the Configuration Manager
- Using the ECB in Report Manager and Route Manager
- Adding for modifying user group privileges for the ECB in Security Manager
Note that the Managed Devices - Group View page in SEM displays the following additional controls for working with Enterprise Plug-ins.
- Add—Launch the SEM dialogs for adding Enterprise devices.
- View—View the selected Enterprise device.
- Launch—Launch the login page for the selected Enterprise device.
