Edit a Network Function with Devices
- Expand the Device Manager slider and click Devices.
- In the Managed Devices pane, expand the appropriate group folder hierarchy, select the NF folder and click Edit.
In the
Edit device group dialog box, change the appropriate parameters:
You cannot edit the NF name or its device(s) IP address(es).Note:
The table in the following procedure displays all possible configuration attributes, but the system displays only the set that corresponds to the selections that you make in this configuration.Name Description User Name field The new device user name. User Password field The new device password. SNMP community name field Enter the SNMP community name for this device, which is the name of an active community where the device can send or receive SNMP performance and fault information.Note:
This field applies only to SNMP version 1 and 2.Note:
The SNMP community must be configured on the device before adding the device to the Session Delivery Manager. Use the device CLI to configure the ip-addresses parameter found in the configure terminal > system > snmp-community element. For more information, See the device product documentation for more information.SNMP port field The SNMP port number. The default SNMP port number is 161. SNMP community name field Enter the SNMP community name for this device, which is the name of an active community where the device can send or receive SNMP performance and fault information.Note:
The SNMP community must be configured on the device before adding the device to the Session Delivery Manager. Use the device CLI to configure the ip-addresses parameter found in the configure terminal > system > snmp-community element. For more information, See the device product documentation for more information.SNMPv3 user name field The SNMP version 3 user name. SNMPv3 authentication protocol drop-down list Select the SNMP version 3 authentication protocol: - SHA—Secure hash algorithm (SHA-1).
- MD5—MD5 hash algorithm.
- NONE
SNMPv3 authentication password field The SNMP version 3 authentication password. SNMPv3 privacy protocol drop-down list Select the SNMP version 3 privacy protocol: - DES—Data encryption standard algorithm (DES) for the encryption of electronic data.
- AES128—Advanced encryption standard (AES) encryption algorithm.
- NONE
SNMPv3 privacy password field The SNMP version 3 privacy password. Web protocols Select the web protocol from the drop-down list. Web port Enter the web port. -
Click
Apply.
A success dialog box displays that the NF was changed.
