SaveDeviceTaskMessage
SaveDeviceTaskMessage contains the result of save and/or activate operation as follows.
- String operation, operation type, Save or SaveAndActivate, Activate
- String tasked, which is task id which will be populated on devicetaskDetails schema once save or save\activate is fully done on server side.
- String username, which contains the user name who is going to perform save or activate operation
- String deviceName, device name the operation is performed.
- String isLockSuccess, specifies SBC Lock status
- isValidationSuccess, does the validation pass for the configuration elements integrity check
- String isEraseCacheSuccess, which is not applicable for granular save
- String isCreateSuccess specifies success or failure
- String isIntegrityCheckSuccess, if EMS count match to the SBC count
- String isRestoreConfigSuccess if Integrity check fail, we need to restore original SBC configuration data.
- String isSaveConfigSuccess, specifies success or failure of Save command
- isActivateConfigSuccess, specifies success or failure of Activate command
- isUnlockSuccess, specifies SBC Unlock status
