SIP Local Map Entry
The following table lists the SOAP attributes and sub-elements for SIP local map entries.
| SOAP Attributes/Sub-elements | ACLI
session-router->local-response-map->entries |
Default Values | Valid Values | SBC Version |
| localerror *#
sipstatus cause sipreason causereason |
local-error
sip-status q850-cause sip-reason q850-reason |
0 | invalid-message, cpu-overload, media-released,
media-not-allocated
100-699 |
4.0.0 and above |
| localerror *# | local-error | invalid-message, cpu-overload, media-released, media-not-allocated, enum-void-route | 4.1.1 and above | |
| localerror *# | local-error | invalid-message, cpu-overload, media-released, media-not-allocated, enum-void-route, monthly-minutes-exceed, next-hop-sa-oos, recv-sa-exc-constraints, revc-sip-int-exc-constraints, next-hop-sa-exc-constraints, next-hop-sip-int-exc-constraints, realm-bw-exc-poly-serv-reject, no-steering-pool-ports-available, allow-anonymous-rejection, sdp-address-mismatch, | 4.1.4; 5.1.1 and above | |
| localerror *#
method registerResponseExpires |
local-error
method register-response-expires |
allow-anonymous-rejection, sdp-address-mismatch, request-method-throttled
empty, REGISTER 0-999999999 |
5.1.1 and above |
