Access Control
The following table lists the SOAP attributes and sub-elements for acess control.
| SOAP Attributes/Sub-elements | ACLI
session-router->access-control |
Default Values | Valid Values | SBC Version |
| inRealm *
inSrc *# InDst *# appProtocol *# transProtocol *# access rateLimit trustLevel errMsgThreshold maxMsgThreshold denyTimer maxMsgThresholdUntrusted |
realm-id
source-address destination-address application-protocol transport-protocol access average-rate-limit trust-level invalid-signal-threshold maximum-signal-threshold deny-period untrusted-signal-threshold |
0.0.0.0
0.0.0.0 all permit 0 none 0 0 30 0 or the same as average-rate-limit |
<realm>
lpv4/mask:port/mask lpv4/mask:port/mask for application-protocol, NONE NONE, SIP, MGCP TCP, UDP, all permit, deny 0-4294967295 none, low, medium, high 0-4294967295 0-4294967295 0-4294967295 |
4.0.0 |
| reservedBandwidth | minimum-reserved-bandwidth | 0 | 0-999999999 | 4.1.4; 5.1.1 and above |
| description | description | 255 characters | 5.1.1 and above | |
| natTrustThreshold | nat-trust-threshold | 0 | 0-65535 | 6.1.0 and above |
| cacFailThreshold
untrustedCacFailThreshold |
cac-fail-threshold
untrusted-cac-failure-threshold |
0
0 |
0-999999999
0-999999999 |
6.2.0 and above |
| inSrc *#
inDst *# |
source-address
destination-address |
ipAddress/mask:port/mask, ipAddress is either ipv4 or ipv6, mask is 32 for ipv4, 128 for ipv6 | CX6.2.0 and above |
