Session Agent
The following table lists SOAP attributes and sub-elements for the session agent.
| SOAP Attributes/Sub-elements | ACLI
session-router->session-agent |
Default Values | Valid Values | SBC Version |
| hostname *#
ipAddress # port state appProtocol # appType transMethod realmID description options SessionAgentMediaProfile acliObjectName *# SessionAgentCarriers acliObjectName *# allowNextHop inTranslationId outTranslationId useConstraints maxNumSessions maxOutbSessions maxBurstRate maxSustainedRate timeToResume noResponseTo inServicePeriod burstWindow sustainedWindow |
hostname
ip-address port state app-protocol app-type transport-method realm-id description options media-profiles carriers allow-next-hop-ip in-translationid outtranslationId constraints max-sessions max-outbound-sessions max-burst-rate max-sustain-rate time-to-resume ttr-no-response in-service-period burst-rate-window sustain-rate-window |
5060
enabled UDP disabled disabled 0 0 0 0 0 0 0 0 0 |
FQDN or ipv4
0.0.0.0 or Ipv4 0, 1025-65535 enabled/disabled SIP or H323 H323-GK or H323-GW for H323 only UDP, UDP+TCP, dynamicTCP, staticTCP empty or <realm> list of comma seperated options List of <media-profiles> for H323 only <media-profile> List of carriers <carrier-code> enabled/disabled empty or <translation-profile> enabled/disabled 0-999999999 0-999999999 0-999999999 0-999999999 0-999999999 0-999999999 0-999999999 0-999999999 0-999999999 |
4.0.0 and above |
| trustMe
proxyMode redirectAct allocMedia responseMap looseRouter inclCarrierAs pingMethod pingInterval |
trust-me
proxy-mode redirect-action send-media-session response-map loose-routing req-uri-carrier-mode ping-method ping-interval |
enabled
enabled disabled None 0 |
enabled/disabled
empty, proxy, redirect, record-route empty, proxy, recurse enabled/disabled empty or <sip-response-code-profile> enabled, disabled None, URI-param, Prefix INFO, OPTIONS 0-999999999 |
4.0.0 and above (for SIP only) |
| localresponseMap
pingToUserPart pingFromUserPart RequesturiHeader acliObjectName *# stopRecurse |
local-response-map
ping-to-user-part ping-from-user-part request-uri-headers stop-recurse |
list of headers list of response codes, 300-599 |
| trustMeForLI | li-trust-me | disabled | enabled/disabled | |
| assertedID
SessionAgentTrunkGroup acliObjectName *# inManipulationId outManipulationId maxRegisterSustainedRate |
p-asserted-id
trunk-group in-manipulationid out-manipulationid max-register-sustain-rate |
0 | sip:name@acme.com or tel:+1234
list of trunk groups or group:context empty or <sip-manipulation> 0-999999999 |
| earlyMediaAllow invalidateRegistrations | early-media-allow
invalidate-registrations |
disabled | empty, none, reverse, both
enabled/disabled |
4.0.1 and above (for SIP only) |
| minSeizure minAnswerSeizureRatio | min-seizures
min-asr |
5
0 |
1-999999999
0-100 |
4.0.1 and above |
| rfc2833-mode
rfc2833-payload |
rfc2833-mode
rfc2833-payload |
none
0 |
none, transparent, preferred
0, 96-127 |
4.1.0 and above for H323 |
| maxInbSessions
maxInbBurstRate maxOutbBurstRate maxInbSustainedRate maxOutbSustainedRate |
max-inbound-sessions
max-inbounds-burst-rate max-outbound-burst-rate max-outbound-sustain-rate |
0
0 0 0 0 |
0-999999999
4.0.1; 4.1.1 and above |
| codecPolicy
inServiceCodes outServicecodes |
codec-policy
in-service-response-codes out-service-response-codes |
empty or <codec-policy>
list of comma-separated response codes, 200-699 |
4.1.1 and above (for SIP only) | |
| rfc2833-mode
rfc2833-payload |
rfc2833-mod
rfc2833-payload |
None
0 |
none, transparent, preferred, dual
0, 96-127 |
| reuse-connections
tcp-keepalive tcp-reconn-Interval enforcementProfile |
reuse-connections
tcp-keepalive tcp-reconn-interval enforcement-profile |
NONE
none 0 |
NONE, TCP
none, disabled, enabled 0, 2-300 empty or <enforcement-profile> |
4.1.4; 5.1.0 and above (for SIP only) |
| maxRegisterBurstRate
registerBurstWindow |
max-register-burst-rate
register-burst-window |
0
0 |
0-999999999
0-999999999 |
4.1.4, 5.1.1 and above (for SIP only) |
| referCallTransfer
pingSendMode egressRealmID |
refer-call-transfer
ping-send-mode egress-realm-id |
disabled
keep-alive |
enabled, disabled
keep-alive, continuous empty or <realm> |
| SessionAgentRateConstraints
method maxInBurstRate maxOutBurstRate maxInSustainedRate maxOutSustainedRate |
rate-constraints
method max-inbound-burst-rate max-outbound-burst-rate max-inbound-sustain-rate max-outbound-sustain-rate |
INVITE, ACK, BYE, REGISTER, CANCEL, PRACK, OPTIONS, INFO, SUBSCRIBE, NOTIFY, REFER, UPDATE, MESSAGE, PUBLISH
5.1.1 and above | |
| hmrString
transMethod reuse-connections |
manipulation-string
transport-method reuse-connections |
UDP
NONE |
UDP, UDP+TCP, dynamicTCP, staticTCP, dynamicTLS, staticTLS, staticSCTP, NONE, TCP, SCTP | 6.1.0 and above (for SIP only) |
| pingAllAddresses
sipProfile sipIsupProfile manipPattern referCallTransfer |
ping-all-addresses
sip-profile sip-isup-profile manipulation-pattern refer-call-transfer |
disabled
disabled |
enabled, disabled
empty or <sip-profile> empty or <sip-isup-profile> disabled, enabled, dynamic |
6.2.0 above (for SIP only) |
| hostname *#
ipAddress |
hostname
ip-address |
fqdn, ipv4, ipv6
ipv4, ipv6 |
CX6.2.0 and above |
