PreviousNextJavaScript must be enabled to correctly display this content
Retrieve Element Metadata and Attributes
You can use the SOAP API to get element metadata and attribute information.
Add the device in Device Manager and load the device in Configuration Manager.
Use the ACP element type:
ConfigMgmtif.getConfigElementMetaData with the string
targetName and
elementType to return all available metadata and attributes for the element type you choose.
The
generate-certificate-request and
import-certificate commands are not supported by the SOAP API.
