Pre-packaged Offline Configuration Templates
The Oracle Communications Session Element Manager includes several pre-packaged offline configuration templates. Each template contains a base configuration for specific types of network environments.
Create a detailed network topology map, including network domain information, such as slots, ports and networks, realms, and their relationships to each other.
Identify device-specific parameters based on the topology map that later become offline configuration data variables.
Oracle Communications recommends that you make a copy of any packaged offline configuration template, so that you can continue to reuse the template for other domains that you may want to create. After you associate an offline configuration with a cluster of devices, the template is no longer available for other devices or clusters. The following table describes the packaged offline configuration templates.
| Pre-packaged Offline Configuration | Network Application |
| SLRM_Standalone |
| CSM_HA |
| CSM_Standalone_SlrmLink | Standalone Oracle Communications Core Session Manager (CSM) configured to work with an SLRM. |
| CSM_HA_SlrmLink | An HA CSM that is configured to work with an SLRM. |
| ASBC_Standalone_SlbSlrmLinks |
| ASBC_HA | Access SBCs for HA 3G to 4G mobile phone network. |
| SR_Standalone | Standalone SBCs. |
| SR_HA | HA SRs. |
| ASBC_HA_SlbSlrmLinks | Access SBCs for high-availability 3G to 4G mobile phone network with SLBs and SLRMs. |
| SLB_Standalone |
