Add a Global Parameter Configuration from a Managed Device
A global parameter configuration stores the configuration changes to be applied in your global parameter work order.- Expand the Configuration Manager slider and click Global parameters.
- In the GP Config tab, click Add.
In the
Add global configuration pane, complete the following fields:
The Category field, and Component, Platform, and Supported software version drop-down lists are not available when the Managed device selection is made.Name Description Configuration name field The unique global parameter configuration name that is an alphanumeric value from 1 to 24 characters with no spaces and no special characters with the exception of the hyphen (-) and underscore (_). Note:
When you choose a name for a new global parameter configuration, this name must not start with the prefix "ID".A validation error (invalid oc name) occurs if the above rules are not followed.
Description field The description of the global parameter configuration. Global configuration seeded from drop-down list Select Software version to load the global parameter configuration from a managed device. Selected Managed device field Select the ellipsis icon (...) to choose the managed device that you want to use as a template for your global parameter configuration. The configuration data model from the selected device is loaded to the global parameter configuration, which contains the elements that are required for this device model and its unique device configuration values. In the Select managed device dialog box, select a device and click OK.
Click
Apply. The following actions are taken:
The global parameter configuration appears in the GP Config table.
