Viewing Top 20 Memory Usage
  1. Expand the Dashboard Manager slider and select Summary view.
  2. In the Top 20 Memory Usage dialog box, a summary of the top 20 devices currently using the most memory the table is sorted by the descending percentage of memory. Mouse over each device to see additional information.
    The Memory Usage column displays the percentage of the memory utilization, followed by a colored bar, which corresponds with the memory usage percentage. The greater the percentage, the longer the bar. A red bar indicates a warning that memory usage is between 90% and 100% and a green bar indicates memory usage is below 90%.
