PreviousNextJavaScript must be enabled to correctly display this content
Launch a Managed Device Login Page
You can use
Oracle Communications Session Element Manager as a single source from which to access and manage multiple products. When you select a device and click
Launch, the system communicates to the device and displays the login page.
Expand the
Device Manager slider, and click
Devices.
On the
Managed Devices - Group View page, select the device that you want to login to.
Click
Launch.
The system displays the login page for the selected device.
