PreviousNextJavaScript must be enabled to correctly display this content
Configure a Device Cluster with an Offline Configuration
You add a device cluster, which can contain a single device group or multiple device groups and associate it with a single offline configuration that you added. All targeted devices in the device cluster must share the same software version, and platform.
