Add a Device to a Device Cluster
Now that you have associated a device cluster to its offline configuration you can add devices to the device cluster.
Pre-requisites: A device is eligible to be added to a device cluster if it meets the following criteria:
- The device must contain a platform and software version that matches the Offline Configuration.
- The device must be accessible through SSH over the network.
- The device has all required entitlements enabled, and licenses installed, as needed, to provide any services enabled by the Offline Configuration.
Ensure that any device that is added to the cluster is not currently being managed by SEM. If a device is being managed by SEM, remove it from SEM so that you can add it to the device cluster.
