Executing Work Order
Once the software upgrade work order is created and its configuration is applied, it can be executed manually (unless you previously scheduled a start date and time for it to execute).
  1. Expand the Configuration Manager slider and click Global parameters.
  2. Click the Admin tab.
  3. In the Work orders table, select the work order you want to execute and click Start.
  4. In the confirmation dialog box, click Yes.
  5. Click Refresh to confirm the status changes for your global parameter work order from Not Scheduled to Running.
