Executing a Work Order on Demand
Once the software upgrade work order is created and its configuration is applied, it can be executed manually (unless you previously scheduled a start date and time for it to execute).
  1. Expand the Device Manager slider and select Software upgrade > Work order administration.
  2. In the Work orders table, select the work order you want to execute and click Start.
  3. In the confirmation dialog box, click Yes.
  4. Click Refresh to confirm the status changes for your software upgrade work order from Not Scheduled to Running.
