Renaming a Device Group
You can rename a device group if it does not belong to another device group at the same hierarchical level.
  1. Expand the Device Manager slider and click Device Groups.
  2. In the Device groups pane, select the device group you want to rename and click Rename.
  3. In the Rename device group dialog box, enter the new name in the Rename device group to field and click OK.
    The new name appears in the Device Groups pane.
