Add a New Reusable Configuration Module from an Existing Software Model Schema
- Expand the Configuration Manager slider and select Configuration Tools > Reusable Modules.
In the
Reusable Configuration module pane, click
Add.
Name Description Name field The unique name of the RCM. Description field The RCM description. Modifiable drop-down list Select from the following user permissions: - Select public to allow any user to modify this RCM.
- Select private to allow only the creator of the RCM to modify this RCM.
Category field Click the ellipsis (...) button to select the Session Delivery (SD) product plugin vendor category: - In the Select network function type dialog box, click SD.
- Click Select.
Component field This field populates with Default (NF component) when the SD product plug-in vendor category is selected. Platform drop-down list Select the platform of the device software on which the RCM is based. Supported software version drop-down list Select the device software version on which the RCM is based. - Click Apply.
