View Managed Devices
When you want to view the details about the configuration of a managed device, use the Devices object in Configuration Manager to display a list of managed devices with the corresponding configuration parameters.
- Expand the Configuration Manager slider and select Devices.
In the
Managed Devices table, the following columns display:
Name Description Name The group, subgroup, network function (NF), and device that belongs to each NF. The grouping structure of the NF and its devices is determined by the Session Delivery plug-in. Software Version The full software release version, including patch number of the NF HA device pair or standalone device. Platform The device hardware platform. Device Configuration Version The configuration version running on the device. This version number changes and increases each time the device configuration is modified. Loaded Configuration Version This is the configuration version number that indicates the last uploaded version of the configuration from the device and stored in the database. This number changes each time a new configuration is uploaded form the device. Last Operation The last operation performed on the NF or its components. Status The status of the last device operation. Status Change Time The time of the last device operation. Pending Changes The number of pending changes for the device. IP Address The device IP address. Target Name (Hidden) The device target name. Category (Hidden) The element manager (EM) plug-in product vendor category. Component (Hidden) The available NF component delivered by the EM plug-in product vendor category. Vendor (Hidden) The plugin vendor to which the devices belong. DeviceConfigId (Hidden) The identity provided by the plugin. For example, the device identity for the plugin is its target name. Object ID (Hidden) The internal database object ID. Group ID (Hidden) The parent group ID. Offline Configuration (Hidden) The name of the offline configuration for the NF device cluster that associates with it. This offline configuration is used to initiate devices (to be added later) to this NF device cluster. Synchronized Mode (Hidden) The synchronized mode column displays if the devices in a scalability group (For example, "Device Cluster" for the plugin) have their individual configurations kept in synchronicity with the configuration defined in the offline configuration as it changes over time.
ScalabilityGroupId (Hidden) The ID of the scalability group. Activation Status (Hidden) Check the device status in a cluster. If the device boots successfully, the Active status displays. If the device fails to activate, the Activation Failed status displays.
