Manage a Device Configuration in a Network Function Device Cluster
When new device variables are added to an offline configuration (in Configuration Manager) that NF device cluster devices use, you must configure each device in a device cluster with its needed device parameters.
  1. Expand the Configuration Manager slider and click Devices.
  2. In the Managed Devices pane, navigate to an NF device cluster device and click Configure.
  3. In the Configure data variable for.... dialog box, enter the required parameter(s) for the data variables for which you are prompted.
  4. Click Finish.
