Delete a Reusable Configuration Module
An RCM is deleted only if it is not assigned to any device or configuration with a dependency. When the RCM is deleted, it is permanently removed from the database and cannot be retrieved.
- Expand the Configuration Manager slider, and select .
- In the Reusable Configuration module table, select the RCM you want to delete, and click Delete.
- In the Delete confirmation dialog, click Yes.
