Rebooting a Device
You must have the appropriate administrator permissions assigned to reboot a device.
  1. Expand the Device Manager slider and click Devices.
  2. In the Managed Devices pane, select the device you want to reboot, and click Admin > Reboot.
  3. In the Confirm dialog box, click Yes.
    The targeted device is rebooted.
  4. Once you see the reboot process finish in the Progress dialog box, click Close.
  5. In the Reboot Device dialog box, click OK.
    This dialog box confirms that the reboot process has completed successfully.
