SNMP Pane
General SNMP Data
Name Description
Authentication traps The SNMP entity is permitted to generate authenticationFailure traps.
In packets The total number of messages delivered to the SNMP entity from the transport service.
Out packets The total number of SNMP messages passed from the SNMP protocol entity to the transport service.
SNMP Inbound Details
Name Description
Bad versions The total number of SNMP messages delivered to the SNMP entity for an unsupported SNMP version.
Bad community names The total number of SNMP messages delivered to the SNMP entity which used a SNMP community name not known to said entity.
Bad community uses The total number of SNMP messages delivered to the SNMP entity which represented an SNMP operation which was not allowed by the SNMP community named in the message.
ASN parse errors The total number of ASN.1 or BER errors encountered by the SNMP entity when decoding received SNMP messages.
Silent drops The total number of GetRequest-PDUs, GetNextRequest-PDUs, GetBulkRequest-PDUs, SetRequest-PDUs, and InformRequest-PDUs delivered to the SNMP entity that were silently dropped. They were dropped because the size of a reply containing an alternate Response-PDU with an empty variable-bindings field was greater than either a local constraint or the maximum message size associated with the originator of the request.
Too bigs The total number of SNMP PDUs delivered to the SNMP protocol entity and for which the value of the error-status field is tooBig.
No such names The total number of SNMP PDUs delivered to the SNMP protocol entity and for which the value of the error-status field is noSuchName.
Bad values The total number of SNMP PDUs delivered to the SNMP protocol entity and for which the value of the error-status field is badValue.
Read only The total number of valid SNMP PDUs delivered to the SNMP protocol entity and for which the value of the error-status field is readOnly.
Generating an SNMP PDU that contains the value readOnly in the error-status field is a protocol error. This value is provided to detect incorrect implementations of SNMP.
General errors The total number of valid SNMP PDUs delivered to the SNMP protocol entity and for which the value of the error-status field is genErr.
Total requested variables The total number of MIB objects retrieved successfully by the SNMP protocol entity as the result of receiving valid SNMP Get-Request and Get-Next PDUs.
Total set variables The total number of MIB objects altered successfully by the SNMP protocol entity as the result of receiving valid SNMP set-Request PDUs.
Get requests The total number of SNMP Get-Request PDUs that have been accepted and processed by the SNMP protocol entity.
Get next requests The total number of SNMP Get-Next PDUs that have been accepted and processed by the SNMP protocol entity.
Set requests The total number of SNMP Set-Request PDUs that have been accepted and processed by the SNMP protocol entity.
Get responses The total number of SNMP Get-Responses that have been accepted and processed by the SNMP protocol entity.
Traps The total number of SNMP Trap PDUs that have been accepted and processed by the SNMP protocol entity.
SNMP Outbound Details
Name Description
Too bigs The total number of SNMP PDUs generated by the SNMP protocol entity and for which the value of the error-status field is tooBig.
No such names The total number of SNMP PDUs generated by the SNMP protocol entity for which the value of the error-status field is noSuchName.
Bad values The total number of SNMP PDUs generated by the SNMP protocol entity for which the value of the error-status field is badValue.
General errors The total number of SNMP PDUs generated by the SNMP protocol entity for which the value of the error-status field is genErr.
Get responses The total number of SNMP Get-Responses generated by the SNMP protocol entity.
Traps The total number of SNMP Trap PDUs generated by the SNMP protocol entity.
