PreviousNextJavaScript must be enabled to correctly display this content
Loading a Global Configuration
Load a global parameter configuration for storing global parameter changes.
Expand the
Configuration Manager slider and click
Global parameters.
In the
GP Config tab, select a global parameter configuration from the table and click
Load.
Once the global parameter configuration loads, the global parameter configuration name appears below the
Global parameters icon. Any configurations made under this folder are contained in the global parameter configuration, and applied to targeted devices through a work order.
The global parameter configuration name also appears at the top of the content area when it is loaded.
