Working with Configuration Views
You can use different Configuration Manager views to navigate the top-level configuration elements of your device by selecting the configuration element and its associated parameters, which appear in the display pane. You can switch between the following views at any time during your session.
Select from the following drop-down list views below the Configuration Manager slider:
- Default view—The top-level configuration elements are grouped into logical, function-specific Oracle Communications Session Delivery Manager category labels that are grouped for a required configuration task and its associated parameters.
- CLI view—The top-level elements display in the active product device folder as they appear and are grouped in the device CLI. The product device configuration labels are listed according to their corresponding CLI parameter format.
- List view—The top-level elements display in an alphabetically-ordered list, and in a CLI parameter format. There is no special grouping as there is with the other two views.
In the
CLI view and
List view, you can see more element attribute columns by checking the
Retrieve all attributes check box. Next, when you select the column arrow menu to access element attribute column selections, all display. See the
Customize the Display section in the
Overview chapter of the
Oracle Communications Session Delivery Manager Administration Guide for more information.
If the Retrieve all attributes check box is checked, it stays checked for the duration of the session.
