Accessing System Data
  1. Expand the Performance Manager slider and select Devices.
  2. In the Devices pane, select and expand a device group folder. The Managed Devices pane displays the following columns for each device:
    Name Description
    Name The descriptive name of the device.
    Version The software version running on the device.
    Platform The hardware version of the device.
    Object ID (Hidden) The internal database object identifier.
    The default device group folder is Home.
  3. Select a device in the device group folder, and click View.
    The Performance Groups folder appears with its performance groups in the navigation pane below the expanded Performance Manager slider.
    If you click a performance group and do not select a device, statistics for the last device are loaded when you click View.
  4. Select the performance group you want.
    The information displayed in the performance group pane depends on your product device and its version, which may be different or more current than the individual performance groups described in this chapter. See your device product documentation for more information. When you access a performance group data for devices that belong to a cluster, data for these devices appears in the content area. The title of each panel is the device name (or IP address) of each device in the cluster.
