Remove a Network Function
When you remove an NF, all references to the NF in Configuration Manager, Device Manager, Fault Manager, Report Manager, Route Manager, Security Manager and Performance Manager are removed.
You cannot remove an NF during a configuration update or if the NF is locked unless you are the owner of the lock or an administrator overrides the lock. An error message appears in both situations. See Override a Locked Network Function section for more information about unlocking an NF.
  1. Expand the Device Manager slider and click Devices.
  2. In the Managed Devices page, click the NF folder you want.
  3. Click Remove.
  4. In the Remove device dialog box, click Yes.
    The NF (folder) and its device(s) are removed from the group hierarchy.
