View Hardware Details for a Network Function Device
You can find the following component inventory data for a NF device, such as chassis, CPU, memory, and so on.
- Expand the Device Manager slider and click Devices.
- In the Managed Devices pane, click to select the device for which you want to show details and click Get Information > Show details.
In the
Hardware tab, the following columns display for NF standalone devices, or an NF HA pair of devices:
Name Description Index (Hidden) The number assigned to each component of the device. Description The text description of the physical entity. Vendor type The vendor-specific hardware type of the physical entity. Note:
This value is different from the definition of MIB-II sysObjectID.Contained in (Hidden) The index number in which this hardware component is contained. Class The enumerated value that indicates the general hardware type of this physical entity. Name Textual name of this physical entity. Name of the component as assigned by the local device. Hardware Rev The vendor-specific hardware revision string for the physical entity. Firmware Rev The vendor-specific firmware revision string for the physical entity. Manufacturer The name of the manufacturer of this physical entity. Model Name The vendor-specific model name identifier string associated with this physical entity. Is FRU This indicates whether this physical entity is considered a field replace unit (FRU) by the vendor. Serial Number The serial number of the chassis or module. Serial number information is pulled from a physical device through SNMP. Virtual devices return a value of N/A. Object ID (Hidden) The database object ID for this device.
