TCP Tab
Name Description
Local address The local IP address for this TCP connection. In the case of a connection in the listen state, the value is 0.0.0.0
Local port The local port number for this TCP connection.
Remote address The remote IP address for this TCP connection.
Remote port The remote port number for this TCP connection.
State The state of this TCP connection. Valid values are:
  • closed
  • listen
  • established
