Edit the Global Parameter Configuration Description
  1. Expand the Configuration Manager slider and click Global parameters.
  2. In the GP Config tab, select the global parameter configuration you want to edit from the table and click Edit.
  3. In the Edit global configuration dialog box, enter the description that you want for this global parameter configuration.
    You cannot edit the global parameter configuration name.
  4. Click OK.
