Modify Element Properties in an Existing Reusable Configuration Modules
- Expand the Configuration Manager slider, and select Configuration Tools > Reusable Modules.
- In the Reusable Configuration module table, select the RCM you want to modify, and click Load.
- Select the element you want to edit in the Elements defined table, and click Edit.
Modify definition.
Name Description Description field Enter a description for the element. RCM action drop-down list Select the configuration action for the targeted element. You can add an element to a configuration, modify an existing configuration element, or remove a configuration element. - An ADD element may not contain any sub-element with a MODIFY or DELETE action.
- A MODIFY action cannot be performed on the parent of any configuration element that is part of an Order Group.
- Required sub-elements cannot be removed from RCM elements with a top level ADD action.
- A MODIFY or DELETE top-level element can only change into an ADD action if all its required sub-elements exist.
- Select ADD to add an element if it is not found in the target work flow.
- Select MODIFY to modify the element if it is found in the target work flow.
- Select DELETE to delete the selected element if it is found in the target work flow.
The provisioning policy rules apply to each RCM action for each element instance level. - Click Apply.
- Click OK to dismiss the confirmation dialog.
