Scheduling a Backup
Use this task to schedule automatic configuration backup for a device or a device group to run once, daily, weekly, or monthly automatically. You can also configure a backup to run on demand. The following actions occur when you create a backup:
- A new directory is created for each device using its device name in the
AcmePacket/ConfigBackups directory. For example:
AcmePacket/ConfigBackups/Oracle-SessionDelivery/AcmeSD/sr177/sr177_2017_04_25_14_22_20_614
- An entry is added to the database for the configuration file.
- The set purge policy is applied.
