Delete a Software Image from the Software Image Archive Directory Expand the Device Manager slider and select Software upgrade > Software image archive. Select the software image file you want to delete from the archive home directory and click Delete. In the success dialog box click OK. The software image file is removed from the Software Image Archive table.
