Identification Tab
Name | Description |
System name | The administratively-assigned name for this node. By convention, this is the node's fully-qualified domain name. If the name is unknown, the value is the zero-length string. |
System contact | The text identification of the contact person for this node, together with information on how to contact this person. If no contact information is known, the value is the zero-length string. |
System location | The physical location of this node. If the location is unknown, the field is left blank. |
System description | The text description of the entity. This value includes the full name and version identification of the system's hardware type, software operating-system, and networking software. |
System objectID | The vendor's authoritative identification of the network management subsystem contained in the entity. This value is allocated within the SMI enterprises subtree (1.3.6.1.4.1) and provides an easy and unambiguous means for determining what kind of box is being managed. |
System uptime | The time (in hundredths of a second) since the network management portion of the system was last re-initialized. |
