Start Report Manager
- On the server where the Oracle database software and BI Publisher are installed, login as the Oracle user.
If undefined, set
the ORACLE_HOME variable in the .bash_profile of both the oracle user and the
nncentral user.
export ORACLE_HOME=/app/oracle/product/11.2.0/dbhome_1
Specify the
ORACLE_SID variable for the AcmeBIPublisher database.
export ORACLE_SID=AcmeBIPublis
Execute the
ORACLE_HOME/bin/sqlplus script.
[oracle@vm bin]$ ./sqlplus '/ as sysdba'
Use the following
option to start the Oracle database instance and exit:
SQL> startup SQL> exit
Specify the
ORACLE_SID variable for the Report Manager database instance (OCSDMDW).
export ORACLE_SID=ocsdmdw
Execute the
Use the following
Start the BI
Publisher database instance listener (LISTENER).
./lsnrctl start
Start the OCSDMDW
database instance listener (LISTENER2).
./lsnrctl start LISTENER2
Change to the
WebLogic server directory:
[oracle@vm ~]$ cd app/OracleMiddleWare/user_projects/domains/bifoundation_domain/bin/
Enter the following
parameters to configure the Oracle user .bash_profile:
export WLS_USER=weblogic export WLS_PW=<my-secure_password>
Start the WebLogic
server by running the
startWebLogic.sh &script.[oracle@vm bin]$ ./startWebLogic.sh &
- Log in as the nncentral user.
Change the
directory to the bin directory.
For example:
cd /home/nncentral/AcmePacket/NNC<version>/bin
Execute the
startnnc.sh script.
./startnnc.sh
The console displays the number of services started. After all services have started, the system is ready for use. Do not attempt to log in until the console has indicated that the web servers are up.
