Create an Oracle Database Instance for BI Publisher
Log in as the
oracle user. For example:
ss -Y oracle@<my_oracle_server>
Run the Database
Creation Assistant.
[oracle@vm ~]$ cd /app/oracle/product/11.2.0/dbhome_1/bin [oracle@vm bin]$ ./dbca
- After the Welcome window, select Create a Database and click Next.
In the
Database
Templates window, select
General
Purpose or Transaction Processing and click
Next.
In the
Database
Identification window, enter
AcmeBIPublisher in
the
Global
Database Name field and click
Next.
The SID is filled in automatically and truncated after 12 characters.
- In the Management Options window, click Next to select the defaults that are provided.
In the Database
Credentials window, select the database credentials option which suits your
needs, enter the password or passwords, and click
Next.
Click
Next to accept the
default settings for each of the following screens:
- Database File Locations
- Recovery Configuration
- Database Content
- Initialization Parameters
- Database Storage
- In the Creation Options window, click Finish.
In the Confirmation
dialog box, click
OK.
Unless you want to create a separate listener for the newly created AcmeBIPublisher database, this error may be safely ignored.
