Download the Repository Creation Utility
Navigate to the
Oracle Software Delivery Cloud and sign in:
https://edelivery.oracle.com/
- Read the Terms and Restrictions, check the two check boxes, and click Continue.
- In the Select a Product Pack drop-down list, select Oracle Business Intelligence Suite Enterprise Edition Plus.
- Click Select Platform, and check the Linux x86-64 check box.
- Click Continue.
- Click Continue again.
- In the license agreement pop-up dialog box, scroll to read the full license agreement, and check the checkbox that confirms that you have read the license.
- Uncheck the checkbox next to the Oracle Business Intelligence application (all software packages are selected by default).
- Click the arrow icon to the left of the Oracle Business Intelligence application to expand all the software packages in the suite.
Check the
Oracle Fusion Middleware Repository Creation Utility checkbox.
This should be the only checkbox that is selected. - Click Continue.
- Click Continue.
- Click Download All to copy all the Oracle Fusion Middleware Repository Creation Utility files to your server.
Log into your server and unzip the RCU files.
unzip <filename>.zip
