Register a Remote Standalone BI Publisher
Use this task if you
entered remote standalone in the previous step:
In the
Register BI
Publisher Step 2 of 2 pane, complete the following fields:
Server Protocol drop-down list Select https or http for the web server protocol. Server Location field The host name of the server on which BI Publisher is installed. Server Port field The BI Publisher xmlpserver port . For example: 7002. FTP User Name field The FTP user name. FTP Password field The FTP password. FTP Path for BI Publisher Home Folder field The FTP path for the BI Publisher Home Folder. For example: /app/OracleMiddleWare/user_projects/domains/bifoundation_domain. The path for your installation may differ if you selected a different location for the OracleMiddleWare directory. FTP Path for Repository Location field The FTP path for the repository location. For example: /home/oracle/Oracle/Middleware/Oracle_Home/user_projects/domains/bi/bidata/components/bipublisher/repository - Click Apply.
