Restart the WebLogic Server to Run Reports
After registering with SDM, enabling SSL or changing the BIP security model, the WebLogic server must be restarted for reports to run properly.
Pre-requisite:You must have an SSH connection to your BI Publisher server. When you are prompted for a password, use the password you set up when installing BI Publisher.
If you set up a standalone, restart the WebLogic server. If you set up a cluster, restart all WebLogic servers in the cluster.
